I'm getting a click in my fork and DVO said it may be the OTT spring, and to take a look and grease it and make sure the spring is clipped in.
Cartridge is out of the fork. There's a black ring that requires a 27mm cone wrench, and there's a green cap/ threaded piece. They said to use a heat gun on the threads to deal with the loctite, then hold the core wrench on the black ring, and use a pin spanner to unscrew the green piece from the black ring. I can't get this thing to budge, and the spanner is starting to leave a tool mark on the green thing.
Anyone done this before? Am I doing anything glaringly wrong?
Thank you!
Sent from my SM-G975U using Tapatalk
Thank you!
