1 - 5 of 5 Posts
So I've got a cheapo frame with a 68mm bottom bracket shell and a cheapo bottom bracket (square taper) that's supposedly 68 or 73mm. It doesn't have a spacer (or one that I could find!) but instead appears that you thread it all the way in on the drive-side and then thread the other side in as far as it goes. I did that and there's like 5mm of threads that remain exposed on the non-drive-side cup. Does this make sense?
I tried threading the non-drive-side in all the way first and then threading the BB in, but it left that 5mm gap between the drive-side cup and the frame. Didn't seem right.
Am I missing something here? Thanks, S
Discussion Starter · #4 ·
Gotcha. That makes sense. Probably does need a spacer then on the drive-side. Then it would leave 2.5mm of threads on the non-drive-side cup exposed. Cool, thanks. Time to dig through the parts box... or stop by the shop. S
Wait, I'm a bit confused now. Does your BB have a lip on anyone of the cups? Adjustable BB's are usually fully threaded on both cups. Each cup can be screwed in all the way inside the shell.
1 - 5 of 5 Posts
