Shimmie
We can always stick something in the mail too!
Adding another 15mm @ .15 thickness will reduce small and mid bump compliance.
It will add good compression for big single hits, but i suspect you'll not like the added hand slap.
Experiment with thinner shims, such as: 21mmX.10. Use 2 of these stacked.
The .10mm thick shims give much more tuning options and greatly reduce the "slap" and if stacked right still retians good big hit compression.
You can usually get all 8mm i.d. in .10mm thickness.
Generally you'll find that reducing the shimmed compression will allow you to run more air pressure for better bottom out and brake dive, with out the added harshness from a combonation of too much pressure and too much compression damping from the shims.
Using the thinner shims also allows the use of thicker oil for better rebound control, again, without the harshness from thick oil and standerd shim stacks.
Alpamayo can attest the smoothness from changing to these shims...
Thin shim stack start point: (starting at piston)
21mm X .10 -qty 1
18mm X .10 -qty 1
12mm X .15 -qty 1
21mm X .15 (this is used as a backer shim, to keep thinner shims from bending too far)
Experiment from there, two .10mm shims will flex easier than one .15mm, so that tells you what you can do with thnner shims stacked for your ride style.
