Having seal issues once again
The history is I have a DUC w/the old black oem seals that would leave some oil rings but never caused oil leaking down to the drop outs.
I went to get it rebuilt -purely maint reasons- and put the Enduro seals in, fork started leaking like a siv and I came to find out the LBS installed the wrong seals. The LBS put in the correct seals but now it appears that one of the seal heads is leaking, whcih Seems like a very odd place for it to leak. I do recall the mech saying that in order for the new seals to work they had to put in new seal heads which requires some glueing.
The only thing I can think of is that either there is some issue now w/a seal head or I inadvertantly spilled some brake fluid on the fork leg after bleeding the brake. Im gonna give everything a real good wipe down and ride again on Fri.
Has anyone had any of these issues?
The LBS is gonna be pretty bummed if I bring it back again as it seems to be a real source of frustration for them and myself.
Anyone got the rebuild/tool kit ofr this fork?
Thanks for any info
wayne
Thanks for any info
wayne
