More ride time?bmrwrld7 said:I'm glad I asked first.. Sounds reasonable to only fix what is broken or should be upgraded.
My 18th birthday is Saturday and I do plan on treating myself to a trip to the bike shop. So far my only upgrade has been to SPD's. What should I get next?
What about stuff for the ENGINE like shorts, jerseys, socks, gloves, etc.bmrwrld7 said:I'm glad I asked first.. Sounds reasonable to only fix what is broken or should be upgraded.
If you do decide to go dual control, make sure to also get a low normal (rapid rise) rear mech. A standard rear mech will be nearly impossible to shift into a higher gear with the lever upsweap motion.GTV8 said:I have a Dual Control setup and I like it allot, its all about personal preference. I think an XTR setup would be overkill and the money could be better spent on other upgrades. BUT, I just noticed that Jenson's has a set of XT Dual Control levers for $73 and LX for $59 that should work with your current mechanical discs. If your bike is an 8 speed then you will have to upgrade to a 9 speed drivetrain (cassette and maybe rear derailleur). So, for around $100 it could be done.
Actually is works just fine- remember with a high normal derailleur the spring is pulling the derailleur down the cassette and all that is needed is to move the lever blade up (I usually shift with just one finger under the lever) until it clicks and release- the derailleur spring will do the rest.goatboy001 said:A standard rear mech will be nearly impossible to shift into a higher gear with the lever upsweap motion.
Wow, that is cool to know. I've never tried it but have always been hesitant to use a high normal mech with dual control levers because I thought I would be fighting the spring with the upsweap motion. I prefer low normal, but have spare high normal mechs. Now I can use them if I have to.VT no 1 2 or 3 said:Actually is works just fine- remember with a high normal derailleur the spring is pulling the derailleur down the cassette and all that is needed is to move the lever blade up (I usually shift with just one finger under the lever) until it clicks and release- the derailleur spring will do the rest.
Never really thought about it like that, I'm glad I posted before buying.rkonindustry said:Wow. XTR duals on a 4300? That's like putting 20" rims on a 89' Datsun pickup.
Spend the money on a decent fork or new tires like stated above. Both would be something you can feel immediately. If you really like the idea of dually's then go LX.
Me too! PHEW, that was close.bmrwrld7 said:Never really thought about it like that, I'm glad I posted before buying.
