1 - 3 of 3 Posts
Hi Guys need your advice here,
I was planning to go on dual chainring setup with middle and granny. As the biggest chain ring is always not in used. I also plan to put in the MRP LRP-2 Chainring system. My only concern is will it fit my frame? and do i need to change the front d to certain type? As i know meta 5 vip 08 dun have the 3 holes around the BB but it does available for BB mount. Another concern is do i need to cut the chain length for dual setup?
There is a lot of room on the Meta 5 and 6 for a 2-ring style guide. I don't think you will have any problems running one. If you are going to use an LRP then get the one for "BB clamp on" and you should not have to change derailluers or anything else. I would also remove some links from you chain if you don't intend on going back to a 3 ring.
Let me know if you need any parts, we have them all at Go-ride.com.
1 - 3 of 3 Posts
