1 - 4 of 4 Posts
Doing custom wheel build and interested in alloy rims, not going carbon...
Narrowed down to the following in order of weight lightest to heaviest:
Raceface Arc Offset 30
DT XM481
WTB ASYM i29
Any pro’s and cons i should be aware of?
Or all relatively the same?
Was leaning toward the arcs...
Keep on Rockin...
I've heard that depending on what rubber you plan on using some beads don't work as well with WTB. That is purely anecdotal however - and others should chime in. I do know that tires I like to use, Maxxis and Spec, work well on DT rims.
I have built one DT 481 front wheel (27.5, 28H, DT 240 straight pull hub, DT double butted spokes and alloy nips). Over 600 miles on it so far. No problems. Like the width: Inner 30mm outer 35mm. I ride mostly cross country and epic(long) rides with a little bit of fun races added for flavor.
urmb
1 - 4 of 4 Posts
