1 - 3 of 3 Posts
So unfortuntaley I trashed my rear XM 1501 rim. Can you get hold of a replacement rim that matches the origional, that I can do a rebuild with. I still have the front so ideally want the rim and decals to match the original.
Can I get hold of a XM1501 rim only from DT? I cant seem to find one
XM1501 rims aren't unique. They're just the high end aluminum rims that DT sells individually with new decals. XM401 - 22.5MM, XM421 - 25MM, XM481 - 30MM, XM521 - 35MM, XM551 - 40MM. Also, these rims are easily over $100.
I don't believe DT caters to 'I want the same decals as stock' types of people. You either buy a new front wheel if you want to be matchy-matchy, or use their individual aftermarket rims.
1 - 3 of 3 Posts
