Got a wheelset using these rims in 24 hole on my Cannodale Rush. They struck me as hard to mount / dismount tyres on when I swapped the stock CrossMarks for a Monorail / Rendez combo.
Well, forget even trying to mount folding bead Kendas on these things! My set of 2.2 Cortez's saw plastic levers bent in half, then out with the MX levers. Just crazy - and these Cortez's just about fall on and off the Mavic 317's on my HT.
Picked up a set of 2.0 Karma's - same thing. Not even worth leaving them on as they will be so hard to dismount on the trail when I get a flat. This is with paper thin rim strips also.
I won't even bother trying to mount any of the wire bead tyres I have lying around....
Ghetto tubeless - forget it! Can't get the tyres over the exposed tube.
Very annoying - I'd hate to be trying to fix a flat in the middle of an XC race with these rims.
So, for next time I get new rubber, what are typically looser fitting XC and trail rubber? (Maxxis being the obvious choice as I can at least get them on + off with not much swearing.....)
