I've been working on a buddy's rear wheel for a couple days now and have narrowed the problem down to the RWS. It is a 10mm composite skewer on a new I9 wheelset (6 mos. old). At first we thought the drag was break in, but I swapped a qr axle from another I9 hub and it spins perfect. It is on an Ibis Mojo sl. I've changed the cassette body along with the big freewheel bearing. It works wonderfully under any circumstances unless the 10mm axle and RWS are installed. All the parts for the RWS seem to be accounted for. I suspect that the problem is some capatibility issue between the skewer and the frame.
I've been dealing with I9 during this narrowing down process and will talk with them more Monday. I was just wondering if any of you guys have had this problem.
btw Industry Nine's customer service is amazing.
