1 - 20 of 69 Posts
thinking of getting these put on my hubs instead of new wheels.
looks pretty fine for a light wide option. 25/30mm inner/outer at 471g for 26"
I assume there's nothing out there on them because they are new? i really have no idea how long they've been out but google is not helping
Discussion Starter · #2 ·
only other thing i found is that Jared Graves is using them this year for EWS...so it must just be the new hotness from DT. Good enough for me; I'll post up later this summer it/when I have some time on them
I just laced a wheelset with EX471 rims. DT350 straight pull hubs (28H), Sapim 2-1.8-2 straight pull spokes.
The rims come with the PHR washers and squorx alloy nipples. It is nice that they give you a couple of extras.
The wheels have been pretty strong in the month that I've used them. No need to retrue. I weigh 190lbs and ride a Pivot Mach 5.7, I consider myself an agressive rider but I take care of my equipment.
I purchased the rims because they were the only "AM" rims in 28H that were wide enough. These are the same rims used in the Spline One EX 1501.
I struggled lacing the wheels due to the squorx nipples. 1) You can't use a nipple driver to start with all the spokes threaded evenly in the nipples. So it is harder to adjust hops. 2) The nipples are very tight as they are the "lock" version so I needed to hold the spokes with pliers to avoid them from twisting. I used WS spoke prep in addition but perhaps it was not needed.
I'm sure I'll be very happy with my wheelset and I would recommend them if you are stuck with 28H. Otherwise I think there are better options for 32H.
Good luck.
Discussion Starter · #4 ·
What would you have gone with for 32h rim? I think highly of DT swiss and the price and spec all seem to add up to a pretty sensible option.
Earlier I had been (and still am to some degree) thinking of i9 enduro, but i have had such good experience with both DT and hope in the past...plus it would come in less expensive and hope has new 40 point rear hubs out now
I would consider Flow EX, WTB i23 or i25. My friends that ride them are super happy and they take abuse. I like the fact that you can use standard brass nipples.
I'm with you on the Hope hubs. They are great for the price now that they come with the 40 points.
I don't want to sound like I don't like the EX471 rims. They are very well made, quality is top notch. I just rather use parts that I can get at any LBS.
I hear the i9 wheels are great, especially the hubs. But I would hate to stop riding for a week or two while I wait for a replacement spoke.
Discussion Starter · #6 ·
I hear ya. It's just that the old flows were more than strong enough for me so I figure shaving a hair of wt would be cool instead of adding a hair. Both are wide. I'm not going to build them myself; I'll see what my preferred builder has to say about the nipple situation.
Was about to mention gwin, hardup beat me to it.
He just rode a dh track including the rock garden racing line on the rim. I think these will be very popular. I know for sure im keen on them.
are those 471s or FR600s that Gwin's using? Either way, SUPER impressive that a rim can take that kind of abuse.
Discussion Starter · #11 ·
Yeah that run was more epic than a wold cup win! Crazy a sub 500g rim coped with that. I thought he was running the 600, too, but definitely the 471. Sucked for Gwin, but DT Swiss couldn't ask for better marketing.
I'm still not on em yet; when I was ready to buy my LBS couldn't get them at the time and haven't checked back in yet
I was really debating rims for my gravity rig, then found this thread. I ordered the 471s in 28h to go with 350s hubs and Competition straight pull spokes.
I'm currently killing myself over aluminum vs brass nipples. The rims come with the squorx aluminum nipples with washers, so I'm thinking that if DT thinks those are good then they're good, but the brass ones are less than 50g more for a 28h set, so why not?
I'll post pics of the build, but UPS has the kit right now.
SO EXCITED
wtb kom is now available in 25mm inner width. Claimed weight of 420g.
I have no appreciation for this in reality, but I would think at that weight there may be a compromise in strength. If they are somehow magically built like a tank and retain that weight, sign me up!
Mike, why did you go 28h vs. 32? I would think for gravity, 32 would be the thing to do. I'm not saying you should have done 32, I was just curious. If you could get away with the 28 and still be stiff enough for DH, that'd be freaking awesome! Also, which Comps did you go with, the 1.8 or 2.0? There's a pretty decent weight difference between the two.
Please post up when you get them set up! I'm really surprised there hasn't been more buzz about these rims after the Gwin thing and knowing Jared Graves uses them on his EWS rig.
I don't want to be a total lemming and use the logic that "Celebrity X uses it, so I should to." That being said, those 2 dudes ride harder than I ever will. It would seem if it's tough enough for them, it'd be a rim that should last me a good while with more pedestrian AM riding.
WTB claims the KOM is a super slick alloy that allows them to use less material.
In my experience as a mechanical engineer, I'm thinking it's probably more of a heat treatment thing, but probably a little of both.
I went 28 because I really wanted to use straight spokes (not j-bend). I don't know anyone who makes a 32-hole straight pull hub. I went with the double butted competition straight-pull 2.0:1.8. So they are 1.8 in the middle.
I'm about to order the brass squorx nipples, but I have a whole bin of normal brass non-squorx nipples. Does anyone have experience using normal nipples with these rims? Washers? They come with supposedly fancy washers and spherical interface squorx nipples, not sure if it's snake oil or a real requirement for the rim drilling.
The squorx nipples are already included with the rim and they are mandatory to use because of the interface with the washers and rim
1 - 20 of 69 Posts
