1 - 8 of 8 Posts
i used it 3 days ago and under the hub section there was an option to see other hub dimensions besides dt swiss..... are they really gone????
it didnt make sense for other manuf. to be up there but i forgot to write the
spoke hole distance down.... and now i cant get the right spoke length....
am i crazy????
does anyone here know the spoke hole distance for a hope pro 2 ss????
am i crazy????
calm down.
what do you want? the flange diameter? it's probably on the hope site
Discussion Starter · #3 ·
thanks....
i dont even know how important the number is... but the dt swiss calculator wont calculate with out it....
0 of spoke hole.....
its under the hub section... and the 0 has a line through it...
i know all the other stuff...
pitch r56 l54
flange offset r33.5 l33.5
or so i was told these were correct....
i need it to work with a 606 edr rim....
i got 294 for both with a guess of 2.5 for spoke hole distance....
thanks
Premium Member
pitch r56 l54
thanks
Just use 2.5. It makes little difference in the results
They just updated with new rim data, and probably inadvertently knocked out the Other hub data. It should probably be back up in a day or two, at least that has been how they've done it in the past.
transmitter~receiver
Like Shig said, it doesn't matter too much.
I usually call the mfr if the info isn't listed on their website or there is any question about it. All of the Hope hub spoke calcs I have saved in my spoke calcualtor have a spoke hole diameter of 2.6mm, and I don't use numbers that I don't have a basis for, so they likely came from Hope USA.
The offsets are 32mm, left and right.
Call Hope USA for the best info:
(936) 756-5004
Their website is hideous and almost completely useless.
Like I already told you, either 293s or 294s will work fine, and I'd use the same length left and right (speaking of the rear wheel only).
FYI: that circle with the line through it is a symbol meaning 'diameter'.
question: didn't you already build this wheel?
Old man on a bike
nicolicious said:
but no, i just built it last night and it came out right after 11 hrs and 3 re lacings.....
thnaks for all your input....
Congrats! Did you get distracted during lacing? :D I can't build a wheel with interruptions, and I need to lay out the parts "just so" so there's no confusion. All I want is some tv/music going to keep me company while I do a wheel...
Hope you're encouraged by the result rather than discouraged by the time invested in any case!
1 - 8 of 8 Posts
