Trying to figure a way to convert a 15mm through front hub to QR. According to DT, the 350 hub is a stand alone 15mm axle due to design. The 15mm axle goes all the way through and directly supports the 15mm bearings and 15mm end caps. I have seen the Mavic 15mm to QR endcap adapters which will slip into the DT encaps, but they do not go deep enough into the hub to catch the bearings, and so the wheel is supported by the encaps alone. I was wondering if I took a 15mm axle and cut i down to the inner dimension of the remaining space (between the Mavic adapters), this would tie the bearings into the DT endcaps. Then the Mavic adapters would support the DT encaps which are centered and connected to the bearings. ANY THOUGHTS?
Apparently these adapters work with the CHUB Hub because the 15mm axle goes all the way through a set of 20mm bearings, but the 350's are different.
Also I wonder how the extra width of about 2 - 3mm of the adapters will affect the front fork operation. The 350 hub is 100mm and the adapters although thin still add width.
I have also seen other brand rim truing adapters for 15mm that go deep enough catch the bearings, but their lip is about 3mm each, and so I know that extra 6mm won't fit.
Maybe I can shave the DT endcaps by the needed overage dimension?:madman:
