What do i need to conver these rims to tubeless? Can I run my non-UST Schwalbe Nobby Nics (2.4s) and just use the standard Stan's kit below?
There are a few options:honourablegeorge said:What do i need to conver these rims to tubeless? Can I run my non-UST Schwalbe Nobby Nics (2.4s) and just use the standard Stan's kit below?
It seems to me that the bead pops up and out away from the center of the rim, with the bead coming into contact with the fold over- of the rim that is evident in the rim profile pic, or the 2nd pic above. The "benches" I think you are referring to are along the flat portion of the rim, where the spoke-holes protrude (please let me know if this is right), are only to allow for easy inflation. Once properly installed, the rim strip sits contained on this flat portion and doesn't creep up into the sidewall, like you can see it doing here:Mr.P said:The 5.1 does not have great benches to support the bead, and the DT Swiss kit adds the inside ridges to the benches to help keep the bead in place (like a UST rim). At least that is what I can see in the pics.
Thanks for the pics and great info Zero.!CharacterZero said:The "benches" I think you are referring to are along the flat portion of the rim, where the spoke-holes protrude (please let me know if this is right), are only to allow for easy inflation. ....
Right on, thanks for the pic.Mr.P said:The ridge on the UST rim, IMHO, is to help prevent burping or bead/beadlock separation during side loads. On a tubed tire, the tube puts opposing pressure on the bead to prevent movement so such a bead bench is not necessary (as can see be seen in the nonUST rim on the right)
P
