1 - 4 of 4 Posts
· Meh.
I see that the fork is available in both 110mm and 130mm versions. Are these forks the same, just with a different travel spacer? Can I drop my fork down to 110mm? Do I just pull the big silver spacer at the top of the left leg out? Or do I move it somewhere? Can somebody point me in the right direction? Thanks.
· Meh.
Discussion Starter · #3 ·
scabrider said:
not trying to thread jack or anything but i had a similar question.
how would you drop the travel on a manipoo stance blunt 150 from 150mm to like 110mm...
If the Stance has a travel adjuster. Pull the top knob off, Pull the spring out. There's a little plastic wedge on the bottom of the spring. Ditch that. Then there's a rod towards the bottom. Unthread it from the uppers. Put a bunch of hose washers on the rod (over the travel adjuster "wings"). Just use as many washers as you want to reduce the travel by. I didn't bother reinstalling the knob or the rest of the travel adjust unit, in case somebody tried to mess with it.
Go down, a few threads, or look in the Lets Talk about Shocks forum. You can see the Sherman I did.
1 - 4 of 4 Posts
