1 - 6 of 6 Posts
Giant STP
Looking to upgrade the MZ Drop Off Comp SC fork on my 2005 Giant STP with the following:
* Quick Release
* Lighter
* Just as strong
* More smooth (MZ is very sticky)
* 100mm travel
It seems as though all the forks that meet these requirements contain 20mm axles. The only other fork that comes to mind is the Rockshox Revelation 426 U-turn, but I'm concerned about the strength in comparison to the Drop Off Comp. Any opinions or other suggestions?
* Quick Release
* Lighter
* Just as strong
* 100mm travel
Minute.
Float.
Giant STP
Discussion Starter · #4 ·
So I guess the Fox 32's are all quick release.
Aren't the Reba, tora, and recon categorized as XC forks? I don't see how any of these can be recommended for light DJ use, unless the Drop Off Comp is that crappy.
I guess i should have guessed about teh dirt jumping by teh bike you ride, sorrry.
I have a Reba and think it is quite strong.(i am about 250 with all my winter gear on). But i think if you want to DJ a through axle would be better.
Do It Yourself
The Reba is the same fork as the Revelation Air with slightly less travel. If you want 100mm air fork, the Reba would probably be the better choice. Maybe you can get some Pike lowers for it so you'll have 20mm. I've seen other people do this on the Reba.
1 - 6 of 6 Posts
