I need a road bike that fits me.
I recently purchased some Midge bars in an attempt to get comfortable on my current bike to no avail.
I must say I adore the Midge's hand position in the drops, the best of my limited experience. I can easily get to the brake lever in the drops which is something I struggled with with other drop bars, an I could ride there all day happily.
The problem is, I can't, even with a steerer extender and riser stem get the bars high enough to function properly for me. Close, but still about an inch to go. Of course, as the bars have come up, they have also come closer, making the cockpit a bit cramped. My current bike is a little too small I am finding.
The reason I need high bars is due to a high saddle position 32-32.5" above the BB. I'm 6'1", with a 36.75" inseam. Unfortunately, the long legs left me with a relatively short torso, and on top of that I'm not particularly flexible and like my MTB bars about 1" below my saddle. From what I can tell I'm built a bit like Matt Chester, so I know there is hope for me with drop bars.
Ultimately, this may culminate in a custom build, but for right now I am considering two options:
Get a Cross Check set up for Midge drop bars. I would use every bit of the X-checks steerer and a riser stem to get to a correct height, but I think it would work.
or
Set up and ride the Monkey as a roadie. The Monkey is nice because the suspension corrected fork brings the front end up...I still use all the steerer available. (also nice because I could then buy a Haro Mary to replace the Monkey's commuter position)
Anyway, I want a versatile roadie that is comfortable to ride in the drops and versatile enough for fenders, racks, etc Having the tops of the Midge's about even or a little higher than the saddle would make me comfortable in the drops.
The questions:
1. Cross Check or Monkey roadie?
2. What size cross check. I ride a (large 24.3ETT) Monkey with a 70mm stem. The road bars sweep forward about 2.5 inches to the inside of the drop where my hand would sit. Should I simply subtract 2.5" from the 24.3 ETT of the Monkey and get the 54 (seems quite small to me), or is it more complex? As the bars come up, you are shortening the cockpit, so could probably get away with a 58 (24.8 ETT)?
3. Should I be considering any other non-custom frames.
or
The questions:
