I'm builing one up. Looking to find out what type and size/pull der. and shifters ya'll using. I've always had shimano on my xc bikes but have broken a couple rear der. Want to go Sram med cage xo or 9, any suggestions?
Hey Bomb, I too am still running 8spd...by choice.Bombardier said:I am a SRAM convert.....
My old trailbike has a full XT kit on it, and I had to constantly fiddle with and clean the drivetrain to get it to work right. But once it got a little dirty, I could say goodby to clean, snappy shifts.
I also got really annoyed by the chainslap that Shimano derailleurs are prone to.
So my Nomad got a full SRAM drivetrain. I went with SRAM's 8spd cassette, and dual Truvativ rings up front.
That also let me run a med-cage XO derailleur, but I'm limited to X-7 triggers because of my choice to go 8spd. This is not a bad thing, because in conjunction with the XO rear d., the shifts are still leaps ahead of Shimano in terms of snappiness and positive shifting.
Even with only 16 speeds, I've not been left wishing for the lost gearing.
It only applies on models that have sufficient "chain growth" for this to be a problem when the suspension compresses. Many designs have this problem, so it is great advice/warning to be aware of it. Riders who have 2-ring setups or are careful to never go to the big/big range, will also avoid this problem regardless of the bike design. This issue is often overlooked by home mechanics...go info.artnshel said:I have a Deore front D, 34.9 top pull, bottom swing I think, the rest is sram, X-9 rear, X0 twist shifters, cassette and chain. If you are doing the build yourself be careful with the chain lenght. I sized it like I normally do, through the rear derailleur and on both big rings but then it was 2 full links too short when using suspension travel.
I noticed that gap too... But I only run into it on gently gradating inclines. It's not always that bothersome, but when it does get on my nerves, I just pop one gear higher and hug it out.TNC said:The 11-32 SRAM just seemed to have a gap I didn't like around 4th cog.
