Ok so I've been riding my Monocog on the stock drivetrain for maybe 100-150 miles total with a couple of rides using an 18t redline cheapo cog before retreating to the 20t again.
Today I decide to try a 17t cog to ride around on the street. When I put it on and spun the freewheel I noticed resistance in one distict spot in the rotation in conjunction with a momentary tightening of the chain. Upon "breaking over" the tight spot the chain appeared to stick to the teeth of the cog and want to try to wrap around. If I look directly down upon the cog while freewheeling it I can see a VERY slight lateral movement which I also could see with the 20t cog. I did the same thing with the chainring and it too looks a hair off. This leads me to the following questions:
1)Could I just run a 1/8" chain to allow the imprecision of the chainring and cog?
2)Should I just replace the chainring?
3)Is the freewheel hub possibly warped causing the SLIGHT lateral movement in the cog? How much is tolerable?
