So I'm into the dropper thing now. :aureola:
Since I've only hit the trail some 15 times the last four years, I'm not prepared to pay much more than €250, preferably less.
My bike is a 2011 Trek TopFuel 8, size 18,5".
There's no holes for a stealth dropper, but I'm thinking of the possibility of making a hole myself, but where should I place it? There's plenty of space on the down tube. I also have one unused hole for a bottle cage on the top, and to holes beneath the downtube. Could the be expanded a bit an used? I assume I can fiddle the cable just past the BB tube for a nice radius bend of the cable.
My current saddle position is 200mm above the clamp (distance A), and I can insert my current post 250mm into the frame (point C). I have about 450mm down to the BB (distance B)
If it's a good idea to cut my own hole for the stealth I can think of two routes, yellow and red, picture 2. I think the red line can just steer clear of the BB spindle. The yellow line is probably to tight of a turn, and it doesn't leave enough insert of the dropper post.
My number one choice for stealth mounted dropper would be OneUp 170mm drop or the e13 TRS+. Cheap solution would be the BrandX XL 170mm.
The easier way would be an external routed dropper, and here I've been looking at BrandX Ascend II with the cable at the seat clamp. The downside is it only has 125mm drop.
Next up is the ExaForm JAG Remote Seatpost 31.6 mm x 485 mm x 150 mm. Various reviews, but it has the stroke I'm looking for. So does the Kind Shock E20. I find the Lev DX too expensive.
So, summary: Cut frame for stealth routing or go with limited number of choises?? 'I hope it all made sense! :thumbsup:
