Tried like a mofo to hammer out with hammer + headset cup removal tool. After literally 500 strikes, net movement was 1mm.
Yeah, I'm sure I could have hit harder and harder, but was reluctant to b/c (1) bike is carbon fiber, (2) rim edge of the inner headset aluminum cup was deforming from the hammer/tool strikes, (3) couldn't imagine what brace I could readily make that wouldn't make me worry abt a frame pressure point. I'm sure lots of folks have given much heavier strikes and with no frame damage, but I was reluctant, esp given bikes in short supply.
Finally, dremel'd out a weak line as in the photo below. This weakened the lower cup rigidity significantly, allowing normal hammer/tool strikes to pop it out.
Man, what an ordeal! All for putting on a 1 degree off set headset. Also, quality kudos I guess to Ibis -- that is a tight fit headtube!
Yeah, hack job, but I'm a hack and didn't want to give up (next time, my objective might be to save 6-7 hours instead).
