A lot of them run 25mm but also a lot don’t, and prefer a more traditional 30mm width, keep that in mind.
Narrower rims are inherently stronger, but also the rim been further inboard of the tire sidewall reduces the chance of rim damage.
The narrower rim will round the tire profile more (since they all run WT style tyres still), increasing maximum lean angles in a perfect world, but as we know tyre deformation is greater with narrower rims and does not provide as stable tyre casing.
The fix? WC level tyre pressures and inserts like CC keep the bead and sidewall stiff and locked on.
So you end up with a strong locked on sidewall and casing, greater lean angle potential and less chance of damage
