So my current situation with the front brake is like here:
https://forums.mtbr.com/brake-time/...en-piston-advancement-retraction-1044785.html
Took the bike to LBS where they changed the caliper. Still looked the same so took it back for a re-check but was told that it's fine as it is. So I am able to align the caliper so that it does not rub (pain in the ass tho because pistons are so uneven) when driving straight, but on uphills or tight curves it still rubs a bit. LBS also told that switching to smaller rotor would probably fix the mentioned rub as smaller rotor would warp less under stress.
Current rotor is almost dead straight - would probably bend it more if tried to fix
To me, that caliper does not look 100% OK and in the other thread OP got new one from SRAM under warranty.
Have already resetted the pistons multiple times and still the inner side pistons move out much more while not retracting much. Outer side pistons barely move.
