You're gonna love it! And once you get a feel for how the bike handles in the air (andplanning my first trip to a down hill park aug 26 to 31 at Snowshoe WV.
I would agree with this.More front brake.
I also have found the same. I first thought it was a bleed block that was too wide for my slightly worn brakes as i couldnt get it to adjust the lever position to where i wanted when fully assembled.I have Sram Guide R on the front and Guide RS on the rear. At first they seemed a little a little more progressive than the Shimano's I was used to, but fine. But as they aged they seemed too soft. Tried new pads and fresh fluid but they still seemed a bit soft. Then last month (before going to Mulberry Gap) I decided to try my own bleed method, at the end after finishing their procedure, I put the syringe back on the bottom opened the system and preloaded a bit of pressure then closed it back up. They have been sweet and tight ever since.
I am very close to positive there was no air in my rear the last time I did the bleed by Sram procedures, as I took the brakes off the bike and hung them so the hose was in a straight line with the caliper lower than the lever. It still pushed out fluid at the end. I'm pretty sure it is a design flaw. As long as I can add a little pressure and they work well I will keep them, if they start having issues again, I will switch to Shimano or Magura.I also have found the same. I first thought it was a bleed block that was too wide for my slightly worn brakes as i couldnt get it to adjust the lever position to where i wanted when fully assembled.
So i pressurized at bottom like you did. Note that this results in fluid expansion out the top if you remove the bleed screw. .??? But fluid is incompressible so either a spring is forcing out the fluid or its an air pocket.
I hen went from 3300 to 9000 altitude at crestted butte and my front brake wouldnt fully release anymore. So i rode it out then later let a tiny bit of fluid bleed out from bottom port to release pressure and we are working again.
So im thinking some trapped air that we are compressing artificially during the bleed.
Thoughts anyone?
I also tried to keep it air free by opening the lower bleed port with the bike tilted back on handlebars against my tailgate. No air could enter. Kept a rag on it to catch excess and the front has been good since (month plus).I am very close to positive there was no air in my rear the last time I did the bleed by Sram procedures, as I took the brakes off the bike and hung them so the hose was in a straight line with the caliper lower than the lever. It still pushed out fluid at the end. I'm pretty sure it is a design flaw. As long as I can add a little pressure and they work well I will keep them, if they start having issues again, I will switch to Shimano or Magura.
For me i think its critical you have the right size bleed block. I was getting a good bleed but after mounting a almost new set of sintered pads couldnt get the adjuster to move lever where i like it. So i pressurized the system a bit and forced the bleed block out after. Its strange that that was fine at 3300 ft but not at 9000 ft. So i have to assume air somewhere.Bleeding according the usual procedure (bleed block, etc.) takes all the air out of the system (including the reservoir) and leaves the correct amount of fluid in the reservoir bladder to allow for fluid expansion and pad wear. Air in the reservoir isn't an issue unless it migrates elsewhere in the system. Air anywhere other than in the reservoir will cause the lever to be soft. If air in the bladder expands, the bladder will take it up. If there's a heck of a lot of air in the reservoir, it might exceed the capacity of the bladder to take up the expansion and it can start to pressurize the system.
