It's inexpensive, it works; it's light, it's fast. 2x9 Nine speed, 11x36 cassette. double chainrings in front, 30 x 42. Climb well, go faster downhill.
Inexpensive as long as these off the back parts keep falling through closeouts. If you want lots of teeth engaged with good chain line on a power climb, you'll want a big ring and not a 32 x 10. Forget about the low end, I can't afford a pancake plate 12 speed. That 51 is way heavier than this setup, god bless you if you can afford to replace titanium cogs. I ride six miles to the trail head, and tried the 1x craze but it was maddeningly stupid twiddling and grinding 32x11.
Even more off the back - the perfect BCD is 94, five arm. That's 90's micro drive!!! There are still low price Vuelta rings available. This way you get the 30, and a good gap to the 42 for the high end. 30 is not double doable in the common four arm 104 BCD, flat rings are too rare. Ritchey was ahead of his time, and I bought a bunch of his 42T authentic 2x9's on closeout for $5 each.
I just rigged up a Profile 180mm BMX crank with a micro drive adapter, the dual suspension has a 90's White Industries crank. There's a particular FSA 19mm exo bottom bracket which works with the Profile, as the Profile BB bearings fail in short order, they're too small when shoved inside the BB.
With a 104 bcd double setup, it's become frustrating finding flat, not narrow wide, chain rings. 32 is all you get with a 104, at least with a double.
So here it is, indexed by the robots, hoping it will help someone else see the light. For a minute this year, Shimano had the XT 180mm M8000 in double, but I can't find them now. And they came without rings.
