i wanted to know what tire psi you guys use for dhilling/freeriding.
Experiment ! Find a pressure that you are comfortable with. If you like 40-50 psi. run that amount. Personally I run about F - 26 psi R - 32 psi for DH, anything more than 35psi feels like my traction is suffering. If I run less than 30psi in the rear my rims seem to flat spot.Stinkyboy58 said:I usually like having my tires, maxxis dh minion with maxxis dh tube, hard and full of air around like 40- 50 psi. Is their any problem with having this much air in the tire??
yeah I agree. I'm lke always around 60-70 whatever I'm doin.PLURPIMPIN said:for urban you gotta go real high, i'm usually around 70-75 psi
just wondering, no flaming....don't you find when you corner hard the tire kind of jumps to the side....does feel all there when you turn???yoonior said:I tend to ride as low pressure as I can (and not to pinch-flat) in the mountains, especially in wet. Usually have 0.2-0.5atm difference between rear and front tires. When I ride some local "jumps", I'd bring up pressure fo sure.
My experience so far (never ridden UST) I could call good setup:
- Intense Intruder DH FRO 2.5, 0.9atm/13psi, front
- Maxxis Minions DH 40,42, High Rollers DH 2.5 40, 42, 1.1atm/16psi front
- Kenda Nevgal StickE DH 2.5, 1.2atm/17psi, front
Yes, I may be lacking some speed due to high rolling resistance but mostly I ride on steep trails within slow/medium speeds. Lot's of rocks and roots. Usually not so dry.
I weight 71kg/157lbs. No huge air, no Whistler-like trails. More like singletrail extreme.
This guy knows what he's talking about. I think anything over 20 psi in a DH tire with heavy side walls is plain stupid. I've found that 2.5 Kenda Nevegal DH tires start losing a lot of traction in wet rooty rocky conditions when they go over 20 psi.yoonior said:I tend to ride as low pressure as I can (and not to pinch-flat) in the mountains, especially in wet. Usually have 0.2-0.5atm difference between rear and front tires. When I ride some local "jumps", I'd bring up pressure fo sure.
Amen! Seems so many people miss the "right rim for the tire" point. I learend from experience myself. Wish I'd purchased wider rims, but I didn't, so I went with narrower tires (2.5 / 2.35) and handling improved.SpawningGround said:If you have to run high pressure to keep cornering control then you have WAAAY too skinny rims for your tires. I think about 90% of the DHFR guys out there actually have too large of tires for their rim size.
SpawningGround said:This guy knows what he's talking about. I think anything over 20 psi in a DH tire with heavy side walls is plain stupid. I've found that 2.5 Kenda Nevegal DH tires start losing a lot of traction in wet rooty rocky conditions when they go over 20 psi.
If you have to run high pressure to keep cornering control then you have WAAAY too skinny rims for your tires. I think about 90% of the DHFR guys out there actually have too large of tires for their rim size. I run the nevegal 2.5 on a 39mm wide rim. I can run it down to -9- psi and still not have it fold over in corners. Most other people I see stupidly cram large tires like these onto 29mm rims and wonder why they can't corner worth a damn.
There's also the traction issue. Someone living in SoCAL isn't going to worry about wet rocks and roots most of the time, so traction in that sense isn't needed. On the other hand, North Shore wet riders like myself need every bit of traction we can get for stunts and wet roots.
If you live in any area thet's wet, you need to run heavy sticky tires at a low PSI on a rim that is wide enough.
I can't stress enough how imprtant it is to use the right size tire for the rim. Most of you are running 2.5-2.8 tires on rims that shouldn't see anything more than a 2.35, thus you compensate for the total lack of cornering control with high PSI and thus destroy your traction.
With a wide rim you get both cornering control and traction. Remember, bigger isn't always better. Your bike will rail corners much better with larger rims or smaller tires.
As I mentioned before, we don't ride here any Whistler-alike trails. No really high-speed stuff, rather slow technical riding. Most of trails we ride are not groomed/prepared mtbiking trails but sort of hiking trails similiar sometimes to narrow Alpine trails.SHIVER ME TIMBERS said:just wondering, no flaming....don't you find when you corner hard the tire kind of jumps to the side....does feel all there when you turn???
