1 - 4 of 4 Posts
Ride On!
Ok, I knew better, my chain broke a bit past the half-way point of a 20 miler.:madman: At least it was the master link that broke (pin came out) and I was able to put it back together, glad I did buy a multi-tool. Got me back most of the way before it broke for good. Going to have to remember to carry and extra one.
Here is my question: In this case is it a good idea to replace the chain or just get another master link? It was skipping on hills a bit before the chain broke, wandering if the chain might have been bent.
It could be bent ,just look at it you should be able to tell. How many miles are on the chain? Skipping is uselly derailleur cable adjustment . Put a new link on it ,pedal it while watching the chain for bent links.That's easier with wheel in the air.
Rogue Exterminator
Could be a worn out chain (not bent)
Bent gear (usually the large chainring)
Worn out gears
Derailleur not tuned properly.
If the chain is in good shape then just put a new master link in.
I carry a new master link and a derailleur hanger with me. Both are something most new riders fail to carry that often brake at the most inconvenient time. Neither take up much space in a pack.
Also I would carry a chain break. That way if you break a derailleur you can shorten the chain and single speed out of the woods.
1 - 4 of 4 Posts
