1 - 20 of 26 Posts
· Registered
Hi All,
Need some suggestions for “spider less” cranks (no chain ring bolts). I have been riding a SS for 5 years and the constant maintaince to quiet the chain ring bolts has run its course.:madman:
Thanks in advance!
DZ
· Registered
Well, its not like you have to melt the chainring. Just warm the ring bolts a bit, one at a time, and they pop off. You do need the special little wrench, I found a broad blade screwdriver just isn't the right tool for the job. My only initial problem was remembering that I had used the red loc-tite and needed to heat the bolts. More than a few grunts and groans on that day.
· Registered
Still, I think it's a bit excessive... To have to resort to a blow torch to change a ring. Why wouldn't you try blue loc-tite first?
· Registered
crux said:
A mix of red and blue actually works very well. Use red on the external surface keeping the bolt from rotating and blue on the threads. Only a small drop is needed on both surfaces keeping everything tight.
When you need to remove the bolt it comes off easily with a small blow from a rubber mallet.
That sounds like a good idea, no red on threads.
1 - 20 of 26 Posts
