with EXACTLY twice the cable pull, I may know a way to divise a simple converter box, to be put in the rear shifter housing where ever you want it, to run ESP shifters with for instance an affordable Shimano derailer, and still benefit from the 1:1 thing. It would even allow for on-the-fly spring tension adjustment. It could even reverse cable pull if it would have to, to work with slow-drop derailers.
But then, however nice the converter box would be, Suntour seems to alreayd have derailers where the positioning of the cable on the derailer can be chosen to be 1:1 or 1:2 anyway, under or over the clamping bolt. Too simple. If only Suntour would figure out how marketing works...
