I was flipping through the new MBA and notice the advertisement for the Marin Quad FRS. If you look at the pictures is looks strangely like the Blur VPP design. Here is the blurb from Marin's Web Site:
"Marin's new QUAD suspension design is a four-bar linkage system with a patented Intelligent Pivot. The Quad system is designed by ex-Formula One engineer, John Whyte and has been developed to give the most responsive and efficient ride over a variety of terrain. This is achieved by allowing the Intelligent Pivot center to mechanically adjust itself, offering riders better traction and control in all conditions. The Quad uses a patented Intelligent Axle Path, its arc is defined by a quadratic equation. The result is a bike that sprints and climbs like a hardtail and is still able to absorb the bigger hits."
and
"Intelligent Wheel Design:
By moving the wheel backwards early in its travel, the system's ability to respond to square edged bumps is greatly improved. Even the smallest bump activates the suspension, keeping the wheel in constant contact with the trail while dramatically improving traction. About 1/3 of the way through the travel, the wheel's arc returns toward the bottom bracket, optimizing chaingrowth and virtually eliminating pedal induced feedback."
What do you guys think, is this a VPP by a different name or not? It sure looks like an exact copy of the VPP design except the pivot locations are slightly different. Their description also seems to mirror exactly the working of the VPP design.
and
