Do you have to buy spacers at a hardware store then? If it's a custom setup then do you have any issues with top-out on the rebound? Can you post a pic of a spacer you used.Mtn. Biker123 said:Sort of, you can use spacers to lower the travel. I have some left over if you need them.
It's not a custom setup.. RS sells the spacer kit...coolatt said:Do you have to buy spacers at a hardware store then? If it's a custom setup then do you have any issues with top-out on the rebound? Can you post a pic of a spacer you used.
