1 - 20 of 28 Posts
I'm in the market for a hardtail freeride MTB and was wondering if there was a bike that can handle 8-10 foot drops, jumps, and still is fast enough for some cc riding and is 1000 dollars or under. I know the old haro escape 8.3s could but are there any bikes out there now for that pirce that can handle that type of riding.
Perhaps a Kona Stinky?
Hard as nails
This could handle it:
http://www.transitionbikes.com/2007/Vagrant.cfm
Take a look at the different manufacturers websites, there are plenty of bikes out there that fit your description. You might have to buy used, or closeout, to get it under a grand. The vagrant or the new, steel Transition AM would fit, but will run you a little more.
GAME ON!
if you can find an evil imperial, go for that. you can use 80mm up to 300mm if you really wanted to
squish is good
Look for used. I just picked up an 05 Norco Shore, very well spec'ed for around $850. There are deals out there, just have to find them.
Discussion Starter · #9 ·
I'd like to buy new if possible but i'll check out some new bikes. What about the Kona five-0? I've been reading some good things about it.
Imperial is out with a low budget like that. New frame would be 3/4 of his budget.... if he can even find one. Used would be half the value... if he can even find one.
GAME ON!
i got a frame for $350 canadian shipped. built it up for not much more than $1100 canadian which is within his budget in USD
Discussion Starter · #14 ·
The problem with this is i don't have much experience in building MTBs, sure i can build a BMX bike from the ground up but that's much simpler as far as i know.
Any info on the Kona five-0 and hoss?
GAME ON!
bmx is pretty similar. just different headsets and bottom brackets - and sometimes not even.
squish is good
Agreed, if you can build a BMX bike you should be good to build a MTB. Hydraulic brakes, shifters, and cables would be the only difficulty but we could talk you through that.
The 5-0 is a good AM hardtail, the Hoss is a Clyde trail bike or an average rider DJ bike.
Honestly if I were you I'd check out the classifieds over at www.pinkbike.com
case in point, this Banshee Morphine is listed for $800 CAD (thats approx. $700 USD).
Thats a helluva lot of bike for the money. (it's not mine either, no spamming here ;) )
Still a child inside...
Banshee Morphine, Yakuza Bakuto/Chimpira, Transition Vagrant...
Also search here Fr hardtail, there were good threads about it
1 - 20 of 28 Posts
