From what I understand RS had problems with 2-Step and it appears from some of the threads in the shocks forum (thanks DenJen) that they are having probs with the dual position forks.Fix the Spade said:Serious question, is dual position air any different to 2-Step?
I am well aware of the 2-step system and it's reliability, I processed warranty claims for several sets of Lyriks that had decided 115mm was all the travel they ever wanted.TheRed said:From what I understand RS had problems with 2-Step
Sucks to hear this. Especially with my Revelation Dual Position arriving tomorrow...denjen said:Do a search in the Shocks and suspension section. I have seen several posts recently were people are having trouble with the Dual position system. it drops done to 120 and wont come back up.
Its a shame because I was getting ready to order a Dual Position, but after hearing of the problems I think I am going to just get a Dual Air.
Very much different mechanism. No hydraulics in dual position.Fix the Spade said:Serious question, is dual position air any different to 2-Step?
Dual air or dual position?djball said:My dual air Rev was a nightmare, new O rings didn't fix the leaks either. Maybe the new ones are improved but it was common problem, I tossed the thing and bought a Sektor air, which I really like so far.
Hopefully you will be ok. Some people are saying the dual position works great but a handful are having trouble.JayDial said:Sucks to hear this. Especially with my Revelation Dual Position arriving tomorrow...
Get in touch with SRAM/Rockshox warranty, either through the shop you bought from or contact them directly (get email from RS website).I've search for solution for this problem but without success.
Is anybody here who can help please?
Here in Europe is RS support not so strong as in USGet in touch with SRAM/Rockshox warranty, either through the shop you bought from or contact them directly (get email from RS website).
Don't know anything about the DPA internals, my advice would be to ask about getting a solo or dual air spring fitted instead. I know that means you lose travel adjust, but you won't miss it if the fork works instead.
Lucky one!Mine fixed itself after a few rides... I can't tell what was the cause or fix. Looks like the check valves of the mechanism get stuck or something.
At any rate and in hindsight, get the Sektor Coil U-Turn and upgrade the damper side instead. It may be cheaper though not as light.
DPA was hit or miss. I can't tell if RS fixed it nor not.
