Whenever I would clean my bike (Epic 29er) I notice that the rebound on the rear shock would be set all the way fast. I always thought the knob would turn it self (I know not very plausible) or would get moved somehow when I was picking the bike up. I have noticed over the past 2 days that this is also happening with my '12 epic 29er.
This got me thinking and I have now realized when I remove the water bottle, from the left side which is easier due to the air valve on the shock, it rubs against the knob and turns it toward fast. If I remove the bottle to the right it also rubs but turns the knob less because the bottle puts most of the pressure on the air valve not the rebound knob. I have always removed the bottle from the left side due to the air valve. I tried removing it to the right on my ride today. At the end of my ride the knob was 2 clicks towards slow from where it started, also it is a lot harder imo to removed and put the bottle back when doing it from the right side, mostly due to the air valve.
I am using a specialized rib cage and switch between a purist and camelbak bottle, I have noticed it happens with both bottles.
I doubt I am the only one with this issue since it happens with both my bottles. If you have an Epic 29er can you check what your rebound is set to and let me know which way it is turned (if at all) ?
My plan as of now is to get a side loading bottle cage, which should hopefully eliminate the problem.
