I live in Sunny NW Florida. I feel that temp management is a necessary part of a light. I have been using Taskled drivers BECAUSE of the thermal management. I have had my triple MCE throttle back to level 3 many times during slow climbs. Yes, I'm slow most of the rest of the time also. Without more finning, active cooling (aka. cosmo) or LN2, cutting back the power in a overheat condition is the only way to save the LED's. As Vroom posted, excessive heat WILL shorten the led's life, and it will shorten the controllers life. Most importantly though, above 25C, the amount of light emitted falls off. According to the MCE spec sheet, output flux falls to less than 80% at 100C junction temp. Also, the junctions thermal resistance is 3 deg C/watt (from led's heatsink to star). Then we got 2 deg C/watt from the star to the lamp housing. This is a long torturous path that the heat has to flow from the led to the heatsink. To say the above in a different way, we need to move the heat from the led to the heatsink. We need to hold the junction temp as near to 25C as we can. Every watt put into the led raises the junction temp by 5 deg C. The bottom line is this; for heatsinks, the more the better. Now (for all you arty-farty types) the job is to make all that heatsink pretty. Think "round bottom Finns". James
