Spec'ing out my dream build and was wondering if XTR brakes are center lock only? How would they bolt up to CK hubs?
Are you sure it was poor tolerance with the interface and not the pads grabbing at the rotor arms?tscheezy said:I have some XT hubs with centerlocks and am experiencing the first vibrations and noise ever from my Louise and Marta brakes when paired with these rotors. Front or rear, it does not matter, they are making noises my 6 bolt rotors never did with these brakes. I am very suspicious of these things. The mounting is not as solid as 6 bolt styles. I would not go the centerlock route again.
The pads to not scrape any more of the rotor spoke than the stock rotors experience. In fact, perhaps less. This was certainly an issue when I tried some Hope rotors with the Maggies. That was a no-go. But that is a totally differnt issue, and it sounds very different. This is a shimmy-vibration, not a surging stutter like when the pads are getting hung up on rotor spokes.XSL_WiLL said:Are you sure it was poor tolerance with the interface and not the pads grabbing at the rotor arms?
While I don't doubt you, I'm always a bit leary mixing and matching disc rotors from manufacturers. I know people do it without adverse effects, but there are enough slight differences for me to think twice about it - track size, rotor thickness, etc... So, I think you're a little quick coming to the conclusion that it's the centerlock design that's at fault for the shimmy.tscheezy said:The pads to not scrape any more of the rotor spoke than the stock rotors experience. In fact, perhaps less. This was certainly an issue when I tried some Hope rotors with the Maggies. That was a no-go. But that is a totally differnt issue, and it sounds very different. This is a shimmy-vibration, not a surging stutter like when the pads are getting hung up on rotor spokes.
