1 - 15 of 15 Posts
Do it for Deegan
Right now I have a 8 speed cassette and I thought a 10 speed would fit because the cogs are closer together but the guy at the bike shop said that if i jump to a 10 speed from an 8 then I would need a new hub because the cassette would be to wide. Is this true?
Do it for Deegan
Discussion Starter · #4 ·
Like Nater said 8 & 10 speed cassettes will work on the same freehub body. You just need to be sure you have a cassette and not a freewheel.
I was worried the bike shop owner was just trying to pull one on me and I always take what a shop owner says with a large grain of salt because
i know they just want me to buy buy buy. Yes it is 100% a cassette body.
NedwannaB
TRAIL 29 5 - Trail 29er - Hardtail 29er - Mountain - Bikes - 2013 (bike)
Hubbs: CANNONDALE C4 - Thats all it says on the websites specifications
I would just take your wheel in to the shop that you patronize with the intent to buy components/or at least have them do the conversion, and have the mechanic swap one on to check it out. Surely they'll have a used 10 spd cassette laying around to do a test run on your wheel. ~5 min procedure. If not, find another shop. ;)
Do it for Deegan
Discussion Starter · #10 ·
Just got back from a shop were I offered to pop my wheel off myself which already had the chain and cassette removed from the bike so they would literally just have to set a 10 speed cassette on it which would take less than a minute of their time and they blew me off. It was even the shop I got my bike from. Needless to say they wont be getting any business from me anymore.
NedwannaB
That's crazy. Hopefully other shops close by that will help and get your buiz.
You are doing a complete drivetrain swap right? shifter, derailleur, and chain? maybe you are getting blown off because its not compatible with the rest of your bike.
Also why do you need a 10sp? I am on 11 speed now but in truth I have seen no improvement in gear range since 3x 8sp. The switch from 7 speed to 8 speed compact drive (w/20t grannie) when i finally consistently started to clean techy 20% climbs was the last time a gear swap truly improved my riding.
Trail Tire TV on blogger
ya, I kinda agree, though I do like 9 speed, and not just the "range" but I always hated the large hop of the final grannie ring on the cassette, kinda wish they had made an 8 (or even 7) that was more distributed in the low/mid range. don't much care about the "math" of gearing as it never makes much sense when actually riding. Never have I done the shift front a ring and the rear 2 or what ever to get the next step in gearing. just shift the front or the rear it's self depending on what I was heading into.
but back to the point.. yes, 8-9-10 speed should be all interchangeable with cassettes.
Do it for Deegan
Discussion Starter · #15 ·
Im changing every drivetrain component because all mine were entry level and the only thing entry level about me is my price range. I was already over riding my components the first day on the trail with them. With my riding style and the terrain I ride on I need the most secure drivetrain I can get hence the 1x with a clutched derailleur. The reason im upgrading from my 8 speed is because its getting faded from the market so I want components that are current and everyone seems to be sticking with or close to 10. I am in no way doing a needless conversion.
1 - 15 of 15 Posts
