I just picked up a SC Megatower and it came specced with a RC Super Deluxe Ultimate (air) and I'm having a heck of a time setting this up.
I'm 225 lbs geared up. I set the shock to 255 psi (11 psi over SC's recommendation) to get to 30% sag. I found it was bottoming out a bit too easy. Even just bunny hopping (18-24") would cause it to bottom out. Now, the bike is supposed to be progressive enough to run coil and you can even spec it that way from the factory so I was surprised that I would need volume spacers just to be able to bunny hop it.
So I added two volume spacers, set the sag to 30% (244 psi). On the trail I was still bottoming out on small jumps. I increased the LSC from 4 clicks out to completely closed. This felt noticeably better and improved bottom out resistance somewhat. I'll still have to add more volume spacers to be able to hit everything I normally do at my local trails. However, it feels like there's no support until the last few mm's of the stroke. If my wheels leave the ground, the indicator ring will be within a few mm of the bottom out point.
I still plan to try it with more volume spacers but I find it strange I'm having to stuff this shock with spacers when the bike is made progressive enough for coil. A lot of reviewers were even saying the compression tune felt stiff for them and they ended up running the sag at 32-33% to soften things up. I think either the shock compression is tuned way too light for my weight or there's something wrong with it. I'm trying to figure out if I should a) have it retuned, b) send it back to Rockshox, c) buy a different shock (X2). Thoughts?
