1 - 13 of 13 Posts
The component in question is an XT that's adorned my 5spot for the last 3 years, since it's inception. Performance had deteriorated the last month or so, so I disconnected the cable to see what was up.
As I moved the cage thru its range manually, the motion was indexed and never came to its natural resting place(in line with the small ring) without a little push from my finger.
I have to imagine all the joints on these things are bushings, right? So drenching them with tri-flow as I did today will probably only exacerbate the problem.
Is there anything that can be done about this, or is time for a new one? I hate having to replace parts that you can't really upgrade. I mean come on, who gets hot and bothered over an XTR front derailleur? Maybe I can have it dipped in gold or something. ;)
No, that's not phonetic
Do you have a mark on your chainstay yoke that would correspond with the bottom of the der cage where the two could meet at suspension bottom-out?
I have had front ders "seize" and I suspect that getting smashed by the swing arm may have something to do with it. Only the front ders on my full suspension bikes have ever gotten stiff. Never on hard tails or road bikes. I suspect foul play.
Pixie Dust Addict
The front derailleur on my Flux is an XT that seizes up from time to time. I usually drench it in a solvent tank to clean out any crud that has built up. I'll then blow it out with a compressor and add a few drops of Tri-Flow to the pivots. After that, it seems to work OK for another year or so.
Discussion Starter · #4 ·
I have 3 rings and matching chainstays, so my front changer is sky high. No chance of contact.
Nevermind the cause, is there a solution?
Natl. Champ DH Poser/Hack
stiff to the point of index is a new one on me. cheesey may be right about the contact. other than that, the pivots in the parrallelogram do wear out over time but 3 years seems a bit fast. if ya can shake it up n down or side to side on the bike by grabbin the tail of the cage, its killed. maybe if ya soaked it in milk......
I still have almost every component I've ever bought (except chains, of course). What I don't have I gave away in a huge box to that soldier in Iraq who was requesting bike parts a few months ago. I still use the front and rear derailleurs and XTR shift/brake levers I got on a bike in 1998. I got modern stuff but I treat them all the same, which is: cleaning when really dirty, no high pressure cleaning AND lubing of every joint/pivot that moves. I've used Finish Line Dry for a long long time. I've never subscribed to the theory that these parts wear out...and they haven't for me. Caveat: I don't live near an ocean, like Dusty and tscheezy. Lube lube lube. That is all.
yep. thats about all ya can do. straight simple green works well if ya give it 12 to 24 hours submerged. any wet lube is good. i use tri flow, t9 or rock n roll blue dependin on the season and conditions. tri flow for dry and clean, t9 for dry and dusty, r n r for wet n shytty.
~Disc~Golf~
is there any way to see what's causing the bind? I know that sounds elementary. But really study it while moving it through it's range--pivots, swing arms, springs etc..use a finger from your free hand to 'feel' areas when the binding occurs, something should be evident.
Unless you bashed it somehow, I'd suspect it's most likely contaminated w/ grit. Although, the 'indexing' you spoke about is some what perplexing...If your mech was contaminated for a period of time, the bushings could have worn down leaving 'sweet-spots' (?). --but I can only imagine what could happen as I have never seen it happen as you describe.
ride
I see that from time to time - like when you have to push it to go back to granny position. If it's not bent, I'll saturate the der in White Lightning and blow it out with an air compressor. Repeat until freed up. I like WL for applications like this because it's very light and non oil based so it won't attract dust and dirt.
Rolling
Good question.
This is a 1997 XTR front D, Top swing. It is on a bike with 18,000 miles on it. This derailleur has been on it the whole time.
It's sometimes hesitates going from middle to large ring but still works well.
However, it's on a hardtail, not a Turner.
1 - 13 of 13 Posts
