OK...I'll set myself up for this. I rode a Cyclo-cross bike for the first time last fall and it was faster than stink climbing a hill. At first I thought it was the fact that it weighed 18lbs, but I got to thinkin'. Could the 700c wheels have anything to do with it? Everyone says I'm wrong but let me present this.
If you are in the same gears on a 26" and a 29" wheeled bike. Everytime you turn the crank the distance the wheel travels is different. Let's say you are in a gear where 1 crank turn results in 1 turn of the cassette. For every crank turn, a 26" bike will travel (pi x d = 3.14x26") 81.64". However, the 29er will go 91.06" or 10" further with the larger wheels.
Now the argument I get is that the 29er is not necessarily faster because of the additional effort required due to the larger torque arm of the wheel. In other words, rocks and general frictional resistance create a larger force because they act further out on a 29" wheel (Torque=ForcexDistance). But is it a direct relationship???
My argument is that although the Torque created by "friction" is greater, the rolling resistance is less because the larger diameter rolls over impediments easier. So there is an advantage when it comes to speed.
Also a 29'er will weigh a bit more because it has larger wheels and tires. But my sense is you may pick up at most an additional pound.
So let the discussion begin. Do 29ers have an inherent advantage over a 26" bike based on the Wheel size? Are cyclo-cross bikes fast because of the 700c wheels and the inherent geometry or is it just weight that is involved. If they do have an advantage then why does NORBA and others allow Cyclocross and 29er's to compete head up against 26" bikes??? Shouldn't they have a weight penalty???
Have at it!!!
Have at it!!!
