Rear shock for frame with slot for 190x50mm shock
  • DNM AOY-36RC
    Votes: 0 0.0%
  • SR Suntour Raidon
    Votes: 0 0.0%
1 - 4 of 4 Posts
Hello everyone,
I want to buy a DNM rear shock for a frame that accepts 190x50mm shock. DNM AO-38RC and SR Suntour Raidon fit perfectly, I know that for a fact (I've seen pictures).
I saw online reviews of DNM AOY-36RC that convinced me to want to use it. But the AOY-36RC is a 190x45mm shock. I would like your thoughts about using AOY-36RC. I realize it has 5mm less travel. From what I understand, there are no other drawbacks. If I agree to that compromise, what other issues I might encounter and will it work at all?
Basically I have budget for one of these three rear shocks:
  • DNM AOY-36RC
  • DNM AO-38RC
  • SR Suntour Raidon
Suggest away. Frame in question is SERAPH FM038.
Discussion Starter · #4 ·
If anyone stumbles upon this at future point in time, I believe the DNM AOY-36RC will fit just fine if someone is willing to sacrifice the 5mm shock travel. Note that 5mm shock travel normally equals more than 10mm frame travel, so have that in mind when willing to make the sacrifice.
Since I'm not a pro rider and don't need shock with dual adjustment, I'll go with the DNM AO-38RC after all. Should be the same shock, only with slightly less adjustment.
1 - 4 of 4 Posts
