Have any of you taken any scientific measurements of the head tube and seat tube angels on your Django 29?
I'm asking because I have a 2017, which I love, and I have always relied on the numbers from the Devinci site for my model year..."LO" setting: HTA 68; STA 74.5. For 2017, they spec'd a 130mm fork. For 2018 and forward, they have spec'd a 140mm fork. Now that I'm about to service my fork, I'm going to extend the airshaft to 140 to be like the new builds.
I was curious if the geometry changed for 2018 with the longer fork, and curiously, the HTA stayed the same but the site shows the STA steepening by .8 degrees from 74.5 to 75.3, on the size M. It seems the longer fork should have slackened both STA and HTA by at least .5 degrees if no other adjustments were made to the frame.
So, I contacted Devinci to ask if they used headset cup or a different offset fork to keep the geometry the same and if the frame could had possibly been updated with a steeper STA angle for 2018 and new. They replied quickly and I was informed that no changes were made to the frame and that there has only been 1 generation of the Django 29 frame. So, what gives? Which geometry numbers are correct...2017 or 2018/2019.
Take a look at the links below for reference. Geos for carbon and aluminum are the same. Not a big deal, but I was just curious if anyone had any measurements. A little mystery, albeit trivial, I'd like to solve.
2017 Trail 29 (Devinci 29 and Marshall)
2018 Django 29
2019 Django 29
2018 Django 29
2019 Django 29
