Just wanted to share my build. Thanks to Achesalot, .40AET and il2mb. Your builds blazed a great path for me to use as a guide.
I tried to make something that would be repeatable and require as little work as possible, particularly work with expensive tools that I don't own. I ended up coming up with something that can be done with a soldering iron, drill, screwdriver, plexi-glass knife and a file. I have a Dremel and grinder, so I used those to make it easier, but the knife and file would have been fine.
I ordered the aluminum tube precut from onlinemetals.com along with a precut L angle piece for the LED mount. I used the basic idea from il2mb's 'DIY done cheap' for my housing. However, to avoid drilling and tapping into the aluminum wall, I used threaded rods to 'sandwich' the light together between two pieces of plexi-glass.
(http://forums.mtbr.com/showthread.php?t=355347)
For the electronics, I pretty much used achesalot's copper head page as a guide. I had trouble finding a 5k pot though, so I opted for a three position switch and resistors from Radio Shack.
(http://bikeled.org/copperhead/Copperhead.html)
Thanks again for everyone that shared instructions and tips. You guys made this a very easy project for a novice to complete.
By the way, it's incredibly bright. I can already see my store bought light getting retired.
