DIY tire inserts is just an experiment. Been thinking about tire inserts for about a year after Schwalbe came out with the Pro-Core inserts. I think tire inserts are a good idea but the weight (usually 200-350 grams) and cost (100-200) is kind of a deterrent. Was thinking of using pool noodles to try out but couldn't find one with the correct diameter, but found some plumbing insulation that is correct fit. So, final weight is 62 grams for 27.5 and cost was 5 bucks. Used shipping tape to seal up the split and tape sections together. Also, made it so it was snug to the rim.
Seems like you can run lower pressures. You can almost ride with no air. Haha. Been holding air fine and haven't noticed differences in riding characteristics. There are some issues. Not sure if the sealant is flowing really freely around but it could be because tire has not been losing air. However, not sure how it will seal punctures. It is more difficult to put the sealant in because you insert through the valve very slowly otherwise it will overflow. However like I said, the tire has sealed up fine and holding air fine. I do have so ideas of improving it.
It is just an experiment because I haven't found anybody who has made a tire insert product that I like. Just food for thought.
