1 - 9 of 9 Posts
Master of None
Anyone come up with a way for mounting a light battery pack to the frame w/o a water bottle cage?
I've seen commercial lights with a bag and a velcro strap, maybe something like that?
I plan to use 6x 18650 cells, probably mounted on the downtube.
I have used mailing tubes with velcro straps. Works great and is pretty much crash proof and waterproof. and is lighter than aluminum. I will post pics later if I can
cheap water bottle cage and a small digital camera pack from Walmart. The digital camera pack has a loop on the back that can be slipped over the top of the water bottle cage.
mounted mine in an under the seat pack, just made the wire a little longer and use velcro in two spots to attach to the frame. My skills dictate keeping the weight back as far as possible...
I built my 2.6AH pack using 10x AA batterries in series. The pack was built using 2" ABS tubing as a 'form' to mold the pack around. After building the pack, I cut about 1/3 of the tube lengthwise, so it's no longer a tube but a 'U' shape piece of plastic. Stuck the pack to this plastic and attached using electrical tape and heat-shrink. Using a saw and file, I left little tabs in the plastic on either end of the battery and drilled a hole in each tab. The pack is then lowered onto the downtube as an upside-down 'U' and screwed to the water bottle bosses. It's secure, waterproof, relatively light, and the location keeps the center of gravity low. Hope this makes sense as it's kind of hard to explain without a pic...
Good luck and have fun with it.
1 - 9 of 9 Posts
