I followed the Dual Control advertising and found the following write-up. Their points seem pretty weak if you ask me.
http://bike.shimano.com/publish/con...e/shimano_technology/dual_control_levers.html
Dual Control Levers
1. Shifts & brakes simultaneously and from a variety of hand positions.
Other shifters require a specific hand placement to execute a shift. Dual Control allows many different variations, including shifting from bar ends to complete a shift.
This means that regardless of terrain, conditions, or maneuvers, a shift can
be completed as desired. The option even remains for use of a thumb lever.
No other controllers do NOT require specific hand positions. They are about as specific as dual control levers. For Grip Shift, the variability is even greater.
2. Adapts to YOUR hands and riding style. Lever pivots in two axis to obtain an optimal position in both angle and reach.
Position the brake lever (both angle and reach) in an optimal position for a wide variety of hand sizes, preferences, and riding styles. Of course trigger systems can be adjusted for angle and reach, however, the angle of the brake lever is dependent on the angle of the shifter. So, the trigger shifter position must first be set so that the triggers can be reached and then the brake lever must then be set at the best possible position that remains.
The "shifter" on a Dual Control unit is adjustable for position as you adjust the "brake lever" for reach. This means a much more customized fit for a great variety of hand sizes. The added benefit of a lever that pivots in two axes, creating less potential for bent or broken brake lever blades in the event of contact with the ground, trees, etc.
WHAT???
The system adapts to me??? Does this mean the controls automatically morph themselves while I'm riding. Or does it mean I have to put the control where I like like any other system.
The angle of the brake is NOT dependent on the angle of shifters. The brake and shifting bodies are on completely opposite sides of the bar. The tricky part is getting things set up laterally, not the angle.
As far as busting the brake on trees. I'm sure it's relieving to know that any destructive blow to the brake lever will also take out the shifter. The old method of loosening the attachment bolts so the unit will move under shock is just fine for me. The other excellent method is big bar end that protect your hands and brake levers.
BTW, as far as durability goes, you'll never beat a twist shifter. And as far as mechanics in general go ... the more parts a device has, the more prone to breakage it is. These shifters have to have a LOT of parts.
3. More intuitive shifting is easier for users to learn and execute.
The function of the Dual Control levers, when combined with a Low Normal rear derailleur, is much more intuitive therefore, easier to explain to users. This is because you perform the same movement for both left and right levers for higher and lower gears.
The most intuitive shifting is the one you already know. As far as "upshifts" and "downshifts", I don't believe most people think of it this way. On the right, you "grab gears". On the front you grab rings or drop them.
4. Simple integration.
One clamp, one fixing bolt, one adjustment and less weight.
One shifter, one available braking system. You want hydraulic with an integrated shifter??? Ahh, than you'll need a Shimano hydraulic brake. No Hayes, Avid or Hope for you!!!!!
Nothing against this mode of shifting, but this advertising is pretty lame. But I guess you have to do a lot of advertising to convince someone to adopt such an expensive system that provides little benefit over traditional trigger and grip shifting.
Dual Control Levers
WHAT???
