1 - 6 of 6 Posts
Weekend Warrior
I thought my V's brakes were the best for my type of riding, which it was for the last year since I started it up again. I have a lot of Power, enough to put me over the handle bars, and I love to slam my front brake to lift of my rear wheel while I sit in the saddle....
...anyways, My riding style has changed a bit and I'm "braver" and getting out on Wet and partially muddy trails and V's are not made for that type of riding. I already bought some DT Swiss Disk compatible Wheels and am looking for Disk Brakes.
What should I look for? I found some great deals on AVID BB7's (around $50 each). Also I was looking at some Hayes MX 1's and 2's, also I found a really "cheap" Gator Hydraulic system in around the same price range.
I weight #180 lbs and was thinking to go with a 180mm front and 160mm rear disks. Or should I go bigger?
Any help here is welcome as I see some people who switch from V's to Disk are disappointed. Thanks in advance
BTW, I have an 08 Specialized Rockhopper, currently with a Dart 3 shock.
The BB7's can't be beat in their price range. For mechanical there really is no other brake.
I don't know anything about the Gator brake, but I would stay the hell away from it. Cheap hydros are a headache (possibly death inducing..) waiting to happen. For new the Formula k18 is as cheap as I would go, and even then you're looking at ~$140 per brake. Used you could find a set of Hayes Mag for 60-80 bucks, just make sure you don't need to replace the pads or rotors or it will get pricey fast.
You must be willing to maintain either mechs or hydros, and the consequences are generally more dire if you don't maintain a hydro.
You shouldn't need rotors bigger than that unless you are getting more into hardcore downhilling.
You won't be disappointed with discs as long as they're set up right.
Weekend Warrior
Discussion Starter · #3 ·
Yeah, that's what I thought. I'm about to order the BB7's; I just need to find a good deal...
BTW, Any recommendations on cables? I'm looking at some Jagwire cables, anything I should consider?
Thanks very much...
Flak jacket cables/housing and speed dial levers. Other than that there are plenty of BB7 masters who can chime in here... A search should find lots of BB7 setup tips (and entertaining arguments...)
Weekend Warrior
Discussion Starter · #5 ·
I already go thte Speed Dial Ti Levers, they are awesome. I also checked out the video on the installation.. Thanks... I guess I'll be riding Disk next weekend.
1 - 6 of 6 Posts
