Hi all
Any one has an idea how to make a floating disc system. I ride a 06 stinky and I have designed the adapter ( the part caliper is mounted on) and the floating arm ( which connects the adapter to the front triangle) In Solid works and I have no problem with CNCing them out . but im a little confused how to fit the adapter on my rear hub . It’s a standard hub with 10 mm quick release axel and 135mm width .there is no room for the adapter pivot point .Should I replace on of the nuts with the adapter or what??
I have saw pictures of non floating bikes mounting self designed systems but no detail was obvious .
Or maybe like Kona DOPE place the adapter out side the frame? But how to fix it there?
