1 - 2 of 2 Posts
I am currently using a 05 hope m4 disc brake and the disc size should be 180mm.
I have replaced the rear disc twice and the current disc was bended very early after replacement. Have been keep truing it to avoid heavy drag. But now the disc is so bad that it need to be replaced again.
Does anyone know if I can get a disc made by other manufacturer such as Shimano? Also can I change to a smaller disc such as 160mm? Do I need to get an adapter for that?
Thanks everyone.
Kin
...idios...
It's more likely that there's something wrong with your set-up, like the caliper not be straight in line with the rotor. I've never had any trouble with Hope rotors (standard and floating, various sizes) and as far as I know they aren't known for 'untrueing' themselves.
Check your set-up before spending any money...
1 - 2 of 2 Posts
