yes you can. discbrakeadapters.com. Do not get the one that bolts to the chain stay. This adapter only works with very small calipers, possibly mangura's. I was not able to use it with my Avid's. You want the universal mount (I own both). I have used the universal one on my 99 ziggurat for over a year with perfect results with Juicy 7's.lowmach said:hello-
will i be able to bolt on any IS disc brakes to my 2002 sugar frame?
-low
The holes on your chain stays are for a specific hayes brake. They still make them but I would still get the adapter. The universal adapter also will strengthen your rear left drop out plus it also will never allow your rear wheel to slip totally out if for some reason your rear skewer failed. Plus you can use any size rotors with it and any brakes just like if you had i.s. mounts.lowmach said:thanks for the reply and the link!
BTW: I do have magura brakes. I have no disc rear wheel yet, so I'm currently only running discs on front.
I saw all those mounting holes in the back triangle and assumed it would accept disc brakes.
I have a rear wheel on the way and started looking at those tabs a little closer.
Man the universal adapters are heavy at 123 grams. Oh well got get the discs up.
-low
first you need a trek/fisher specific IS adapter, the holes in the drop out will not bolt up to any manufacturers mount, so you need the trek mount that makes it the 51mm IS.lowmach said:hello-
-low
The Disc-o is the Trek P/N you mentioned. It comes with all the mounting hardware you need. If you can get it, great! It would be tough to have one fabricated without the drawing, then it would need to be CNC milled, due to the various thickness and ledges, then threaded.lowmach said:thats the one i need. i talked to my LBS and they did say the adapter was out of stock at the factory. saying not sure when they will have it again.
I did ask for part #87855. i will assume after reading the post above that this must be the # for the kit. I will call tomorrow and ask just for the adapter and see what part # comes up.
is that disc o mount aftermarket?
thanks for the help.
crimson: the parallel adapter from discbrakeadapter.com would not fit my app. i did contact them and they suggested ii try their universal mount and if it doesn't work then they will let me return it. i would like to try this trek part since i know it will work, but if i can't locate one then i will try the uni mount. thanks for your input.
-Low
that kit has been out of stock for a while says my LBS, but the mount itself is in stock, you just have to buy the bolts seperately, make sure you have the shop source the part number of the seperate mountlowmach said:thats the one i need. i talked to my LBS and they did say the adapter was out of stock at the factory. saying not sure when they will have it again.
-Low
Thanks for the info but what about 2000 Sugars?2inthehole said:sugars from 2001-2003 (sugars 29rs 2003-2006) (and low end sugars from 2004-2005)must use the kit 87855, trek IS adapter, no other company makes this adapter
Me say go disc front, v rear ...... less expensive, likely lighter (especially if you're bolting on an adaptor and all...). Rear disc brakes are overrated, imho....front disc is a "good idea"lowmach said:hello-
-low
2000 sugars didnt have a drop out that was compatible, even some of the early 2001's didnt either, mid 2001 was when they started adding them, but fisher will bond in a new drop out for you and repaint your swing for cheap if you're stuck with one of those.Crash_FLMB said:Thanks for the info but what about 2000 Sugars?
